Re: pic: 1296 Mittens
You guessed our main off season project, honestly the possibilities of running 775pros is just too good for us to ignore. The biggest disadvantages to a 775 drivetrain that we have noticed is robustness (we still are not 100% sure what happened at Dallas) and not being very good for pushing (can't stay at stall torque for very long). Drivetrain cooling is critical. Main advantage is that you get the working torque of a CIM in a stupid small and lightweight package. I think our drivebase with no mechanisms attached weighted in under 30 lbs this year, almost half of that being the wheels. The entire robot has varied between sixty and ninety depending on what iteration the mechanisms were on. Want to talk about building an agile robot? On a completely unrelated note, this discussion has clearly attracted a lot of attention from individual team members. |
Can't quite put my finger on it, but there's something about this robot I just really like... Looking good 1296! See you in STL!
![]() -Brando |
I know in 2012 the Poofs had a drivetrain that had two CIM's per side and a 775 (I think it was a 775) per side as well (with 2-speeds, no less), per this source, and also from me seeing it at Champs. This seems to me like it could be the best of both worlds, and a CIM/775/775Pro hybrid opens up a ton of possibilities.
Quite a few teams have utilised the BB775-18 in conjunction with CIM's in previous seasons. 775's especially the 775pro because of the bearings, are more efficient then CIM's, so this is another advantage. I think that in a shifting gearbox, 775pro’s are highly effective alongside CIM’s or with sufficient cooling could be highly effective alone. 3360’s drivetrain utilises 8 775pro’s that is a lot of power. While the motors may not like being stalled, it is very unlikely they will be stalled in a pushing match (this is more power than 8 CIM’s). Cooling CIM’s with a fan etc. during a match isn’t very effective, because most of the heat is contained in the rotor, in-fact the outer case of the motor continues to heat up after the match ends, because of the heat conducting from the rotor. But with 775pro’s because of the low thermal mass and the fact that they aren’t sealed means that in-match cooling can be used. The 775pro is designed so air is drawn in through the front holes, and is then expelled out the back after it has passed around the rotor. The VP mount has special holes for this, but the holes in the the VP motor input stage, could be enlarged to increase airflow. In the 2014 KOP there was a thing called an “ICE cube” supplied by EBMpapst which allows fan-forced cooling keeping the motor cool, even when the fan is not rotating. It looks ideal for a task like this. http://first.ebmpapst.us/docs/Instruction_RevC.pdf There was some discussion about it on this thread http://www.chiefdelphi.com/forums/sh...ght=775+cooler |
Like you said, with all the power, if we get in a pushing match, the wheels slip instead of stalling the motors. They get warm, maybe hot in elims, but they will not burn |
![]() Quote:
The load rating data sheet, says that the big reduction(7,9,10:1) carrier plates says that they can withstand up to 100 N-m, so your not to close to that, but there are a lot of different stresses in a drivetrain. I suppose part of the reasoning for having the sprocket reduction after the planetary reduction stage was to reduce the torque on the gearbox? Also how often do you grease the gearboxes? Last edited by pilleya : 06-04-2016 at 20:30. |
#11
How many 775 pros did you buy?!
#12
We greased the gearboxes once when we built it, and one more time when we changed the ratios at Montreal. We don't plan on greasing them again |
#13
We got the motor swap down to about 7 minutes per side. On the VPs we weld the pins and bore out the gears putting needle bearings in to spin on the pins and fortunately we did not have any problems. Swapping the VP would have been a much longer task.
