Go to Post Why do it the hard way if you don't have too? - ChrisH [more]
Unread 04-06-2016, 06:39 PM
Kevin_Crossland Kevin_Crossland is offline
FRC #3324
Kevin_Crossland is an unknown quantity at this point
Re: pic: Simple hook delivery system
It looks like it's a literal air cannon - there are no pneumatic cylinders involved. The fitting isn't modified, it's just attached. Inspection would be easy so long as the housing for the canon isn't PVC, PolyCarb, Fiberglass or other material that is prone to splintering during an extreme failure event.
the question I guess would be if it classifies as pneumatic component, I figure if worse comes to worse it's a pressure relief with a conveniently placed harpoon
Unread 04-06-2016, 06:59 PM
joeojazz joeojazz is offline
FRC #5712
joeojazz is an unknown quantity at this point
What type of pneumatic cylinder do you use?
Unread 04-06-2016, 10:57 PM
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Ours just uses the pneumatic cylinder as the latching mechanism to release the crossbow. We just used a 1" or 2" stroke 3/4" bore cylinder. The latex tubing stores all of the energy that fires it up to the bar.
I put the parts into CAD based on memory, since the real mechanism is in the bag. Here's a better angle (click for bigger image):
