Go to Post You can't reprogram physics. - Kevin Sevcik [more]
Unread 13-04-2016, 14:58
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
Re: paper: 4536 scouting database BETA
I believe there is a good chance that I am currently calculating "tech foul count" and/or "tech fouls drawn" improperly. I will be investigating more tonight, but for the time being assume that these metrics are erroneous.
Unread 13-04-2016, 15:38
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Rookie Year: 1997
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Caleb, thank you for pulling this together every week! Our team has been using it as a "pre-assessment" of teams before each event. We will for sure being using it for CMP!
Thanks again!
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
2010 Florida Regional Woodie Flowers Award - Cathy Beck
2011 Florida Regional Woodie Flowers Award - Jack Tusman
Unread 13-04-2016, 16:13
hutchMN hutchMN is offline
2502 alumnus
FRC #4360
hutchMN has a spectacular aura abouthutchMN has a spectacular aura abouthutchMN has a spectacular aura about
Thank you so much for putting this together. It's been a great tool so far.
Unread 13-04-2016, 17:19
Originally Posted by Ben Martin View Post
Thanks for producing this every week! It is very interesting how the results from this data aligns very closely with scoring averages by type in our scouting data (not a perfect match, but very close)--we'll definitely be using it for Championships scouting.
The results align reasonably well with our data as well. We got the most similar results when rounding all negative values up to 0 and rounding all positive values down to the nearest 0.1 or 0.2.
Thanks again!
Thanks for the compliments, I'm glad to hear it is getting some good use.
Unread 13-04-2016, 17:21
Never mind, I think these are still being calculated properly.
The reason I thought these were wrong was primarily a result of me forgetting how exactly tech fouls are scored.
Unread 17-04-2016, 13:08
mitchellzone mitchellzone is offline
FRC #1533
mitchellzone is an unknown quantity at this point
Caleb, this is great stuff, very helpful. The world results sheet makes it great to use for Worlds scouting.
I do have a question on how you've calculated these numbers, though. I'm assuming for a given event you're taking averages, but how do we end up with negative numbers for things like teleop high boulder points, etc.? There are several fields with values like this that I don't understand as the minimum value should really be zero.
Can you explain this? Thanks.
Also, I'm wondering if you'll be producing a sheet that contains only the teams going to Worlds in St. Louis? That would be helpful for those who are going. Thanks for doing this work!
/mike
Unread 17-04-2016, 13:51
FRC #1533
Thought of another couple:
Does this data just reflect qualification rounds or also playoff rounds? I assume the latter, but wanted to verify.
Also, how are you calculating total points? This seems to be a really low number...
/mike
Unread 17-04-2016, 14:40
These numbers are calculated using a least-squares approximation on qualification scores assuming that every team contributes the same amount to the selected category in every match. This value is each team's calculated contribution (or OPR) in that category. The only inputs to the algorithm are the category scoring breakdown per match and the match schedule. For more detail on how OPR is calculated, see the first link on this page titled "Presentation to explain new scouting database."
As to why negative values arise, there are two main reasons this could occur. First, recognize that these values represent a given team's contribution to a given category, which is generally not equivalent to what we conventionally think of as scoring. For example, a team which never takes shots, but transports boulders into the courtyard, could have a positive value in "teleop Boulders High." Although scouts would never say that they scored boulders high, if alliances which they are a part of tend to score more high goals, their "teleop Boulders High" value might be positive. In the same way, if a team plays the game in a way that hinders partners from scoring high boulders (by taking balls from them, taking their desired shooting position, running into them, etc...) then this team will have a justifiably lower score in "teleop Boulders High" than just the average number of boulders they themselves scored high.
The other reason a team could have a negative value in a category boils down to our assumption that every team contributes the same amount every match. This is very clearly false, but it is a reasonable enough approximation that we can still arrive at reasonably good results when making it. If team A never scores in the high goal, but happens to be on the same alliance as a very good shooter in the same match that the shooter breaks down, team A will likely receive a small negative value in "teleop Boulders High."
Personally, when I interpret these values, I generally round all negative values up to 0, but YMMV.
Good idea. I will include a sheet like this in my next update.
I do only factor in qualification rounds. There are a number of reasons for this, many of which are described by Ed Law here. The reasons there are important, but the largest reason for me is that using qualification matches only has become the de facto standard on calculations like these, and it is important to me that my scores are equivalent to those listed on TBA, the 2834 database, and the 1114 database.
Total points is actually equivalent to OPR. This number represents the calculated contribution to the match scores of a team throughout their qualification matches.
Remember that these numbers represent only the given teams' contribution, not their average alliance's score. Also, remember that playoff scores are calculated differently than qual scores. If you want to approximate a playoff alliance's score, you will likely get better results using my eOPR1 or eOPR2 metrics.
Unread 18-04-2016, 09:12
FRC #1533
Okay, knowing these are all calculated similarly to OPR makes sense and explains the numbers, probably including the next one I was going to ask about which was why challenge/scale likelihood was often >1.0.
Looking forward to the next update, thanks.
/mike
