Go to Post There are so much more things to be worked on and are more beneficial to FIRST and FIRSTers than green dots by someone's name. - tiffany34990 [more]
Unread 17-04-2016, 15:55
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
Re: pic: Stripped VexPro gear
Originally Posted by cbale2000 View Post
I'm curious about the circumstances that caused this; I'm having a hard time visualizing how getting stuck in the low bar could cause this kind of damage to a gearbox. Any more details you can share?
Sure. During auto the robot would go through the low bar, and then attempt to back over it. If our alignment was off, when backing up, the robot went in at a slight angle and was pushing against one of the side supports for the bar. The motors proceeded to run while the robot was pushing against the support for a good 5-7 seconds, causing the gears to grind. This happened once or twice until we dialed in our positioning. For context, this gear is part of the third stage on the 2 CIM ball shifter. It actually drives the output shaft.
