Go to Post GDC.... Come on. Counter-clockwise? ... I believe NASCAR might file a lawsuit! - Pavan Dave [more]
Unread 17-04-2016, 20:27
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: pic: Stripped VexPro gear
Not quite...
What usually happens is that if one tooth breaks off, the next tooth takes more force than it would ordinarily (fewer points of the same force being applied = more stress as well), plus a chance of shock loading. Then that one takes off... repeat until you're out of gear teeth.
When only a small number of teeth are removed, there is normally a lot of damage to the other teeth. But this damage doesn't seem that it could be all caused by the normal meshing of the other gear. In this case is it the shrapnel that is the cause of this?
Sponsors, parents, students and mentors love helping teams succeed. Denso Throttle motors also want to help, don't break their hearts. REDBOX(gearbox for the throttle motor)
Facebook
