Go to Post Are quadcopter rotors considered a pneumatic device? - bobbysq [more]
Unread 18-04-2016, 00:10
Landonh12's Avatar
Landonh12 Landonh12 is offline
270 points
AKA: Landon Haugh
FRC #0364 (Team Fusion)
Landonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud ofLandonh12 has much to be proud of
Re: pic: Stripped VexPro gear
We had the same thing happen to us on our scaling mechanism. I believe we were using the 60 tooth 1/2 hex bore gear from VexPro. We have a CIM Motor that has 3 stages of AndyMark GEM Planetaries on it, along with a 1:3 gear ratio coming out of it.. totaling up to around 900 ft/lbs of torque. At Bayou, we went out in the quarter finals because we had 4 teeth shear on that gear. We couldn't scale because the robot sagged and got caught in that section of the gear that had stripped.
We ordered a steel gear from McMasterCarr and welded in a 1/2 inch socket. It worked throughout Rocket City flawlessly.
Team Fusion 364 - Driver/Programmer 2012-2015; Controls Mentor 2016-Present
