Go to Post Yo GDC I'm happy for you and I'm gonna let you finish, but Aim High was the best FRC game of all time! - Brandon Zalinsky [more]
Unread 19-04-2016, 16:23
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Re: pic: 3D printed beveled gears
Originally Posted by cbale2000 View Post
What rpm do they run at? Also what motor/gearbox combination are you using to drive them (and what ratio)?
The whole collector is driven off of a BAG on a Versaplanetary with..... I believe a 100:1 reduction then a (minor) multiplier with an 18t vex gear on the output of the planetary and a 16t on the input of the collector driveshaft. I actually don't remember what the reduction in the VP gearbox is, I'll check whenever I end up back at the shop.
Lucas should be back here to answer any questions about the printers we use.
Just pointing out how amusing it is that you're the MetalCrafters, and you have plastic gears.
¯\_(ツ)_/¯
