Go to Post [Goals For 2012] 1. Build on 20 years of hard work. 2. Inspire a new generation so they come back another year. 3. Repeat. - Koko Ed [more]
Unread 03-01-2016, 01:58
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Re: pic: ABS-114, supercompact planetary PTO shifter
I forgot to update the Partner Space recently it looks like. I just finished, so you can take a look at the CAD here.
I downloaded the ABS 114 folder and it is missing the majority of the SolidWorks files and has no STEP file. Can you do a Pack and Go and flatten?
Unread 03-01-2016, 03:51
Sure, I'll stick that in the folder as well. I think you can download them all from GrabCAD that way but I'm not sure.
EDIT: It's up. Download "ABS-114.zip" in the ABS-114 folder on GrabCAD.
Unread 03-01-2016, 12:12
AKA: -matto-
FRC #1410 (Kraken)
Very cool design!
What material are the planetary gears? 4000 series steel or 7075 aluminum Would you make your own hob to make these (they don't appear to be COTS)?
Still a super cool design
Unread 03-01-2016, 14:01
Very cool design!
The ring gear is a modified SDP-SI S1E10ZM10S072. I tried to avoid making custom gears, and will continue to do so until I can make my own gearcutting machine.
Unread 03-01-2016, 20:39
Aren Siekmeier's Avatar
on walkabout
Took me a bit to figure out how the carrier plate ever gets unlocked, that is neat Just don't apply power while actuating the PTO cylinder!
It's hard to imagine you're using the CIM encoder to line up the locking notches with the cylinder. Can the rounded end of the locking pin ride up the outer contour to get into the notch? Why not make the locking notch the only groove, so the locking pin rides the OD until it engages? Like the locking plate on 118's arm in 2014: http://s22.postimg.org/3sk056lxt/Scr...3_19_25_33.png
Also, for the locking pins, I wonder if you could use something like mcmaster 84835A22 to reduce friction if you want to actuate the PTO cylinder and slide it in into place. You'd have to turn the gearbox slowly to avoid wrecking the lock after PTO engage and before drive disengage.
Unread 03-01-2016, 20:51
I was never really sure how to align it myself, actually. If I try to make the pin ride up on the outer part like a cam, it adds a bunch of weight. I can definitely make some amount of taper though to fix that.
Currently you basically just depend on the encoder.
Unread 03-01-2016, 21:15
on walkabout
I'd predict this to be fraught with problems, since the CIM shaft position is not necessarily linked to the position of the carrier plate or of the ring gear. You'd have to track both of these somehow in code based on how many counts you've accumulated in each of the PTO cylinder and shift cylinder states. And then you don't know what counts you're missing when either cylinder is actuating. But maybe that's not an issue if you never actuate the PTO cylinder until the end, and you can keep track of things well enough.
Seems it'd be more reliable if you can put an encoder on the carrier plate/ring gear themselves (a wheel side encoder might be all you need, if zeroed properly), or just have them automatically engage from any position.
Unread 03-01-2016, 23:42
Ideally a hall effect sensor + magnet on the ring and on the carrier would work.
Unread 05-04-2016, 23:56
Colin Small Colin Small is offline
FRC #0114 (Eagle Strike)
Colin Small is an unknown quantity at this point
Wow! Amazing work! Just curious, what do you do to make pocketing/support structure between mounting/bearing holes in CAD? Do you offset entities on the holes and then connect the expanded material through lines?
Unread 06-04-2016, 01:10
Thank you!
To do pockets, that's basically what I do. After offsetting entities, I connect the centers of some holes with centerlines then offset them to get the inside trusses. The outside contour is made by placing lines tangent to the circles around the edge with the endpoints of the line coincident to the circles. Offset them in one direction and do an extrude-cut and select the areas to remove.
Makes a really nice shape, although sometimes you end up with corners to small to fillet normally. Then you have to use face fillets one at a time.
Unread 06-04-2016, 01:12
Oblarg Oblarg is offline
AKA: Eli Barnett
Nice touch with the socket output. I did this on one of my gearboxes a while back, it's extremely convenient.
"The breakfast of champions!"
Unread 06-04-2016, 02:21
Convenient for the designer definite. As far as using it goes though I prefer having a 1/2" hex output;it's easier for me to connect both sides of the drive for PTO use, and you can more versatility with the placement of your sprocket or pulley or whatever.
Unread 21-04-2016, 21:54
izz's Avatar
izz izz is offline
FRC #1983 (Skunk Works)
izz is an unknown quantity at this point
Hi, I tried to open the CAD file, but it would not on my computer because I use Autodesk Inventor instead of Solidworks. Could you upload step files instead of Solidworks files? If not, does anyone know how to convert the files from Solidworks to Inventor or step? I read online that it was possible to open them in Inventor, but I have tried multiple times and it is not working. Thanks in advance.
Unread 21-04-2016, 22:11
cad321 cad321 is offline
AKA: Brian Wagg
FRC #2386 (Trojans)
What I will do in situations like this is upload the files to my personal workbench account, and then re download them as a step file.
Unread 21-04-2016, 22:20
I can upload as a step. Give me a few minutes.
Solidworks only opens up older Inventor versions, the same could be true of Inventor.
EDIT: It's in the partner space now.
