Go to Post What language does your programming mentor have the most experience with? That's the language you should use. - Rosiebotboss [more]
Unread 22-04-2016, 10:41
XenObliv's Avatar
XenObliv XenObliv is offline
AKA: Phillip Parker
FRC #1902 (Exploding Bacon)
XenObliv is an unknown quantity at this point
Re: pic: Our x1902 Stuffed Oreo, See You In St. Louis
Originally Posted by Max Boord View Post
What compression?
Also have you guys tried running wider wheels or multiple wheels in a line? That seemed to help with accuracy and power over doing the small-big-small wheeled approach.
The ball gets compressed about two and a half inches. We have not tried more than the one lunacy wheel, the smaller wheels are simply be used as flywheels. The compression seems to be only relevant to the friction, which to limit the rotational energy so that more of the total energy goes towards transnational. This gets a straighter shot, one without backspin, allowing us to be very accurate close up.
