Go to Post Jenny - thanks for not beating any of our team members up with their own MOE sticks! That must have taken some willpower to hold yourself back! - Mr MOE [more]
Unread 24-04-2016, 23:04
Colin Small Colin Small is offline
FRC #0114 (Eagle Strike)
Colin Small is an unknown quantity at this point
Re: pic: WIP 3 CIM 2 Speed All Belt Cim Above Tube Gearbox
For your second stage pulleys, they are constrained in rotation by the hex bore. Let's say you accidentally broach one so that the tip of the hex lines up with a groove, and the one next to it such that the flat of the hex lines up with a groove.
At this point the two pulleys do not perfectly match up in their rotations. This wouldn't be a problem, only for their mating pulleys you have the same problem- the teeth may not match up.
This means that you could face some major indexing issues that would screw up the meshes on at least 1 pulley at a time.
The way to fix that would be to use a jig to align the pulleys before broaching/machining.
Ah, I see.
Considering that there'll be three holes for joining the two sets of large pulleys, I don't see a problem with those. If I do end up having this made I'll probably use a jig for the driving pulleys.
