Go to Post If you are playing foozball and your ball bounces back out of the goal, do you expect the table's manufacturer to fix it? No - you groan and keep playing! Nothing's different here. Like Dave said, it's part of the challenge of playing the game. - petek [more]
Unread 24-04-2016, 23:08
Colin Small Colin Small is offline
FRC #0114 (Eagle Strike)
Colin Small is an unknown quantity at this point
Re: pic: WIP 3 CIM 2 Speed All Belt Cim Above Tube Gearbox
Originally Posted by Joey Milia View Post
Yeah, bit curious why you left the first stage gears when you've used them everywhere else. It seems to be the reverse of optimal.
Could you post the tooth counts of each stage and any math you've done to confirm you'll have enough power capacity with the belts.
Also need to think lot harder about that inverse pneumatic. I know this is a rough CAD but what you have could potentially kill the cylinder, way to flimsy.
Otherwise I like how it's turned out.
EDIT: by belts not lining up I think he means if you're not carful how you join the pulleys together one of the two belts might not fit into the teeth correctly.
EDIT2: pneumatic is less flimsy if you have another one the other side. Still could be stronger.
The spacing worked better to have a single large gear for the first stage. It's thinner than pulleys and I'm not concerned with the width of the gearbox.
TBH I haven't done any math for the strength of the belts. Again, I didn't intend this to be a production gearbox and more an experiment/proof of concept/CAD practice. I'll post the tooth totals though. I think it's 18-50, 18-30, and then either 20-50 or 30-40.
What about the paramedics are flimsy? I can always add a support on the back of them.
Edit: I realize that the pictures pneumatic is orientated wrong. The fittings should be either vertical up or horizontal to the outside of the gearbox.
