Re: pic: Another stripped VexPro gear
Steel final gears should be adequate to sort the issue.
Course they are heavier. Every year I try to avoid broaching stuff but I finally got fed up and bought a #5 5 ton ratcheting arbor press and Dumont push broach. Built a nice stand out of 2x4 with caster's for that 365lb monster. I also bought a rotary broach and holder but I am sorting issues out on that. I had 20 and 24 tooth Vex gears because I bought 2 dual CIM Vex ball shifters lightly used from an FRC team on eBay. So I actually have something to test with. Personally I just usually use AndyMark boxes. If figure as CSA sooner or later I am going to run into these Vex products. Last edited by techhelpbb : 29-04-2016 at 20:23. |
We had the same problem at waterloo, We sheared 3 Gears in 7 Matches, its the gears because we used two different gear boxes and they sheared on both
Congrats on making it to Worlds |
More stress than the part was designed to withstand = It breaks. How do you know that you aren't exceeding their advertised ability to withstand static or dynamic loads? Instead of writing "it's the gears", you might need to write "it's our robot"? Blake Last edited by gblake : 29-04-2016 at 20:59. |
I mean you'd have to test it to Vex's specification and then risk testing it in a drivetrain. Testing to Vex's specification would rule out defective gears...testing your drive train would demonstrate a design issue. |
If that happens, you don't write, "it's the gears." Instead you you would write, "it's our robot.", or "it's our driver.", or ... |
We had a VEX gearbox failure in the same type of gearbox. But it was the gears that failed, it was the casing. We took an especially rough underside impact and sheared the CIM right out of the black plastic. So... you know... we drove almost a whole match with a CIM hanging solely on its wires.
(No way were we going to hit that E-Stop) |
The same thing happened to us at the OKC regional. We believe that a bind was caused due to a broken PTO chain and resulted in a stripped gear. We are using these gears on our Vexpro ballshifter gearboxes.
As promised: http://www.chiefdelphi.com/media/photos/43781
