Go to Post Don't give up on others. I believe in killing grumps with a smile! - maltz1881 [more]
Unread 29-04-2016, 20:28
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Re: pic: Another stripped VexPro gear
Originally Posted by Michael Hill View Post
If they can't, you have two choices: find another gearbox or modify the COTS gearbox to make it work.
I think the Vex box is actually pretty nice but:
If your team bought this COTS and managed to avoid buying the broach and press for it and you need to make a modification a few hundred bucks could really hurt. On the flip side of that you could buy extra gears early but first you would need to foresee the issue and then be able to source them...it looks like late in the season the supply chain got tight.
I rarely mind helping and I bet at CMP you might get the machine shop to broach steel gears you might buy just in case: but this could really hurt at competitions less equipped and might be pointless if you did not get suitable steel gears before you need them.
So really it is a design issue, but those 20 tooth steel gears I sent to CMP were AndyMark products broached. There are steel gears you can order on Amazon that could be broached (take longer to get).
BTW recognition to BeardyMentor and Philip for helping me out on this.
