Go to Post Find what your team is good at, and use it in any way you can. - karomata [more]
Unread 29-04-2016, 20:53
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: pic: Another stripped VexPro gear
Originally Posted by 31Josh61 View Post
We had the same problem at waterloo, We sheared 3 Gears in 7 Matches, its the gears because we used two different gear boxes and they sheared on both
Congrats on making it to Worlds
Or ... It might be the way that you are using the gears (or it might not).
More stress than the part was designed to withstand = It breaks.
How do you know that you aren't exceeding their advertised ability to withstand static or dynamic loads?
Instead of writing "it's the gears", you might need to write "it's our robot"?
Blake
Unread 29-04-2016, 20:57
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Originally Posted by gblake View Post
Or ... It might be the way that you are using the gears (or it might not). More stress than the part was designed to withstand = It breaks.
Blake
How would you test that without ruining gears?
I mean you'd have to test it to Vex's specification and then risk testing it in a drivetrain.
Testing to Vex's specification would rule out defective gears...testing your drive train would demonstrate a design issue.
Unread 29-04-2016, 21:00
Michael Hill's Avatar
You just have to calculate the theoretical max torque based on the Lewis gear equation, then include a factor of safety.
Unread 29-04-2016, 21:06
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
All I'm saying is, even the strongest gear teeth will break off when subjected to too much stress.
If that happens, you don't write, "it's the gears." Instead you you would write, "it's our robot.", or "it's our driver.", or ...
Unread 29-04-2016, 21:48
Thayer McCollum's Avatar
Thayer McCollum Thayer McCollum is offline
[Insert Name Here]
FRC #0159 (Alpine Robotics)
Rookie Year: 2015
Thayer McCollum will become famous soon enoughThayer McCollum will become famous soon enough
We had a VEX gearbox failure in the same type of gearbox. But it was the gears that failed, it was the casing. We took an especially rough underside impact and sheared the CIM right out of the black plastic. So... you know... we drove almost a whole match with a CIM hanging solely on its wires. (No way were we going to hit that E-Stop)
Unread 29-04-2016, 23:03
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
The same thing happened to us at the OKC regional. We believe that a bind was caused due to a broken PTO chain and resulted in a stripped gear. We are using these gears on our Vexpro ballshifter gearboxes.
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 29-04-2016, 23:30
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
As promised: http://www.chiefdelphi.com/media/photos/43781
