Go to Post Smart defense doesn't even require your robot to push another. - Cory [more]
Unread 02-05-2016, 11:23
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Re: pic: Another stripped VexPro gear
Originally Posted by LSanchez439 View Post
When you say 'broach' them some steel gears, what exactly are you referring to?
Buy a gear with a 1/2" round hole (also maybe a keyway) and push broach it 1/2" hexagonal.
The push broach looks like this (this one is from Dumont):
http://www.andymark.com/product-p/am-2204.htm
It fits in either a hydraulic or arbor press.
The 20 tooth steel gear I did for other teams look like this before I broach them:
http://www.andymark.com/Gear-p/am-0186.htm
You know that intelligence test where you put the round peg, in the round hole and the square peg, in the square hole?
In this case you push with about 1,100lbs of force until the round hole chisels out to a hexagon
Proving once and for all - brute force can solve problems.
Unread 02-05-2016, 12:16
MVCI MVCI is offline
MVCI is an unknown quantity at this point
Is the output direct driving a wheel (ie output shaft going through a rigid frame)? Look into the possibility for relative motion between the output gear and its driving gear. This could be caused by loose transmission mounting or flexing of the plastic case. With extra load/impacts on the gears being part of this game and improper gear mesh (caused by relative motion between gears) I imagine this could easily happen.
Unread 02-05-2016, 12:18
Reptilefox's Avatar
Reptilefox Reptilefox is offline
FRC #3230
Reptilefox is a glorious beacon of lightReptilefox is a glorious beacon of lightReptilefox is a glorious beacon of lightReptilefox is a glorious beacon of lightReptilefox is a glorious beacon of light
That exact thing happened to us (3230) at the Idaho Regional!
