Go to Post We can be equal, but not truly the same. - Molten [more]
Unread 03-05-2016, 10:04
CJ_Elliott's Avatar
CJ_Elliott CJ_Elliott is offline
FRC #2502 (Talon Robotics)
CJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of lightCJ_Elliott is a glorious beacon of light
pic: I know this isn't a competition but...
Unread 03-05-2016, 10:06
TAlholm's Avatar
TAlholm TAlholm is offline
Mainely CAD
AKA: Tim Alholm
TAlholm is just really niceTAlholm is just really niceTAlholm is just really niceTAlholm is just really nice
Re: pic: I know this isn't a competition but...
This happened to us at Hartford and Worlds. Customer service is amazing when this happens!
FRC Team 1991 (2013 - 2016) - Head of Design / Head of Scouting
Don't trust me to cut down a straight line, unless it's on an automated router or mill.
Unread 03-05-2016, 12:44
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
I see I've started a "post your broken gears" phenomenon.
Unread 03-05-2016, 13:57
Oblarg Oblarg is offline
AKA: Eli Barnett
Are these the 14t gears? We had the exact same failure at our first district. Swapped them for steel replacements.
We also noticed some significant wear on the input gears, which seemed to be due to our CIMs getting pushed out of position (from inboard to outboard). We secured them with hose clamps and the problem went away - a nice trick to remember for the future.
"The breakfast of champions!"
Unread 03-05-2016, 20:03
CJ_Elliott's Avatar
These are the 14t gears in the second reduction. We also switched to steel for champs and had success with them there. Lessons learned. Although I do not we have experienced any problems with the pinion gears on the CIMs. I will check again and thanks for the heads up.
Unread 03-05-2016, 21:36
AKA: Eli Barnett
It was the gear the pinions were meshing with that was taking most of the beating, not the pinions themselves. I've got a pic that I'll upload later tonight.
