Go to Post It doesn't matter what goes wrong as long as you have fun. We all thought this was one of our best trips, even though we were second to last in our divison. - afowl [more]
Unread 03-05-2016, 12:48
phargo#1018 phargo#1018 is offline
AKA: Peter Argo
FRC #1018 (RoboDevils)
phargo#1018 will become famous soon enough
Re: paper: Talon SRX Breakout Boards
Regarding the library models, what I typically found is that the component I was using wasn't in the library.
I've used a lot of DC-DC converters,circular connectors, fiber transmitters and receivers; things that aren't mainstream, but are needed.
I also found that I could solder 1206 SMT patterns if I made my own pattern with longer pads. I am sure the off the shelf libraries work fine for the professional machines - I was working low quantity prototypes.
Thanks for the google pointer ... I will probably have more questions.
Unread 06-05-2016, 12:21
AKA: Peter Argo
Still working on the PCB design effort!
I looked into a number of Altium related items; honestly, their library capabilities appear to be a brick wall (perhaps a rock wall!). Most of the library information I can find is targeted at Altium version 10 or below. Their present distribution is at 16. Is anybody really using this package???
I am concentrating on free software versions. The first I ran into was geda. Gnu based and primarily intended for use on Linux systems. I am still working on getting up to speed on both! I think this has the highest payoff if I can make the Windows to Linux transition.
What I have been the most productive with is KiCAD. Free ... windows based ... able to create library entries, able to associate footprints with components. KiCAD is definitely clunky to use, although working through one design gets the user up to speed pretty fast.
I was able to do this in 3 or 4 evenings having never used the package, but with several years of CAD experience ... several years ago!
Comments?
Unread 06-05-2016, 12:30
marshall's Avatar
marshall marshall is online now
FRC #0900 (The Zebracorns)
Comments?
No idea... outside of my realm of expertise but if you are having that much trouble then try CADSoft's EAGLE. It's by far the most popular EDA package for the hoboy-set.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 06-05-2016, 13:08
QFT. You can also upload the native Eagle .brd files to Oshpark for ordering PCBs, allowing you to skip making CAM files. This lets me upload 8 or 9 times per design, as it shows you a preview of what it will look like and lets you catch errors or sketchy situations easily.
That being said, making custom parts in Eagle can be arduous if you're not used to it. There are no convenient dimensioning tools like Solidworks' Smart Dimension. You either have to go by the dimension grid, or type in coordinates for each part manually.
