Re: pic: Swerrrve
Nice job!
I like how you integrated everything into the frame members. That should reduce the overall weight. I would also like to see the CAD for it and get into the finer details. |
Re: pic: Swerrrve
![]() Quote:
Just uploaded: https://grabcad.com/library/2nd-swer...-in-progress-1 Quote:
Here it is: https://grabcad.com/library/2nd-swer...-in-progress-1 |
Re: pic: Swerrrve
Oh and don't mind the lightening holes. Thats just how I waste time when I get bored
Re: pic: Swerrrve
Now that I've seen the CAD:
1. Why chains over belt for the first stage? That's going to be running at a rather high speed. 2. You might have trouble with the round spacers on the bottom of the casterboxes, because you are using screws on both sides. Why not either use a screw + nut or hex standoffs so you can get a wrench on it? 3. Why live axles over dead axle on the last stage, and why 3/8" bearings instead of just thunderhex bearings? It saves some machining imo. 4. Are you sure that the casterbox won't hit the VP output shaft when it turns? I can't tell from the model. Apart from that it looks good. |
