Go to Post No caffine for you! - Koko Ed [more]
Unread 04-05-2016, 19:48
SerpentEagle's Avatar
SerpentEagle SerpentEagle is offline
AKA: Shashank Rajesh
FRC #3641 (The Flying Toasters)
Rookie Year: 2015
SerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to beholdSerpentEagle is a splendid one to behold
Re: pic: Swerrrve
Originally Posted by kyle_hamblett View Post
That's a good chunk of power behind each wheel. I have never seen a swerve with a CIM + miniCIM combination. Also, bumpers give it the 2451-esque feel
Now all it needs is an underglow
Definitely looks better with the CIM + MiniCIM setup on each corner, and I like how you've kept up the small form factor on the first stage reduction gearboxes!
I think your bumper supports could be a bit more aggressive, but maybe that's just me.
Thanks! Yeah, the way the bumpers are supported is a little weird.. I'm trying to explore different ways of doing stuff
Originally Posted by Roboshant View Post
grabcad link?
Just uploaded: https://grabcad.com/library/2nd-swer...-in-progress-1
Originally Posted by Kevin Ainsworth View Post
Nice job!
I like how you integrated everything into the frame members.
That should reduce the overall weight.
I would also like to see the CAD for it and get into the finer details.
Thanks!
Here it is: https://grabcad.com/library/2nd-swer...-in-progress-1
Unread 04-05-2016, 19:54
Rookie Year: 2015
Re: pic: Swerrrve
Oh and don't mind the lightening holes. Thats just how I waste time when I get bored
Unread 04-05-2016, 20:09
Re: pic: Swerrrve
Now that I've seen the CAD:
1. Why chains over belt for the first stage? That's going to be running at a rather high speed.
2. You might have trouble with the round spacers on the bottom of the casterboxes, because you are using screws on both sides. Why not either use a screw + nut or hex standoffs so you can get a wrench on it?
3. Why live axles over dead axle on the last stage, and why 3/8" bearings instead of just thunderhex bearings? It saves some machining imo.
4. Are you sure that the casterbox won't hit the VP output shaft when it turns? I can't tell from the model.
Apart from that it looks good.
