Go to Post ROBUST, ROBUST and ROBUST if you want to win - dan 322 [more]
Unread 06-05-2016, 20:46
phargo#1018 phargo#1018 is offline
AKA: Peter Argo
FRC #1018 (RoboDevils)
phargo#1018 will become famous soon enough
Re: paper: Talon SRX Breakout Boards
I didn't realize the vault application had to be downloaded separately.
Will it require a separate license, or is it included with the FIRST agreement?
Sincerely, thanks to all for the pointers!!
Download is in process, let's see where this leads!!
Between Eagle and KiCAD, I found KiCAD to be more suitable ... could just be me!
Unread 08-05-2016, 19:24
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
The Altium Content Vault isn't a seperate download. The instructions (https://techdocs.altium.com/display/...+Content+Vault) should be enough to show you how to install, setup and use the included libraries.
The main disadvantage is that it's all stored server-side so access speeds are not that fast (this is where they normaly make money, by charging for a local Vault).
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
