Go to Post A great mentor guides without giving the answers, teaches through discovery, demonstrates without lecturing, provides support from backstage, observes without hovering, and leads by example. - dlavery [more]
Unread 11-05-2016, 09:00
Ari423's Avatar
Ari423 Ari423 is offline
FRC #5987 (Galaxia)
Re: pic: ARJ-101 full view
This looks really cool! I would very much like to see the CAD for it so I can get a closer look.
2017-present: Mentor FRC 5987
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
Unread 11-05-2016, 10:29
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Awfully difficult to tell from this view how possible it would be, but you could introduce more reduction using a planetary gearbox, which would also give you a larger shaft to work with for the ball shifting. Of course, that would increase the footprint substantially.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 11-05-2016, 11:07
Kevin Ainsworth's Avatar
FRC #2451 (Pwnage)
Cool stuff. Sometimes ideas that you decide are not feasible later get you thinking about other ways to do what you want. Our in wheel swerve design from 2014 got more attention than our coaxial from 2015, but was heavier, only a single speed, made speed feedback difficult but still everyone liked it better because it was different from the norm. I am now on the coaxial bandwagon since sensing wheel speed and shifting are very difficult with distributed swerve designs. Getting the motor power wires and the pneumatic lines for the shifter cylinder through the steering pivot without requiring steering limit stops would be an issue. Your designs have come a long way and its been fun watching them progress. Keep going and show us something revolutionary!!!
Unread 11-05-2016, 11:27
nathannfm's Avatar
AKA: Nathan
FRC #3940
If you use a planitary you could shift like they do in hand drils by engaging or disengaging some of the ring gear.
Unread 11-05-2016, 13:22
CAD is in the 2015 offseason release: https://workbench.grabcad.com/workbe...1Z2b-tQWAq3gUh
Look under CIMshift -> 101 to find this assembly.
This is a planetary shifter, actually. You shift between just a 72:25 (?) reduction and a 72:25 x (60:20 + 1) double reduction, by tying the second planetary to the first one.
I can totally see that. Personally I did like your CIM-in-wheel, but aftermaking some of my own decided the weight and space weren't worth it.
Thank you!
See above. However, if I were to just disengage one set, the spread will be very low; I'll be moving from a ratio of 4:1 to 5:1, or 3:1 to 4:1 just because of the way planetaries work.
Unread 14-05-2016, 21:57
cad321 cad321 is offline
AKA: Brian Wagg
FRC #2386 (Trojans)
Would the shifter built into the cim shaft not be considered modification of the motor? I suppose you could argue that if you can put a flat on a shaft, machining a few extra holes in it wouldn't be much different.
Unread 14-05-2016, 22:02
R30 A. The mounting brackets and/or output shaft/interface may be modified to facilitate the physical
connection of the motor to the ROBOT and actuated part.
If the output shaft can be cut down to a stub, to inteface with a Versa-planetary, a few holes isn't an issue.
If would be quite interested to see how something like this would hold up under operation, it is a relatively thin shaft, and drilling holes is going to weaken it considerably
Unread 14-05-2016, 23:55
Basically this whole design was based off R30 A.
I doubt this would hold up as I'm removing most of the material in the CIM shaft, but given that each CIM is only driving one relatively small wheel, it might not be too bad. I didn't bother to do the calculations before because the radial holes for the balls screw up traditional torsion calcs.
