Go to Post FIRST really does enjoy watching us squirm with their teasers, don't they? - Anupam Goli [more]
Unread 16-05-2016, 15:06
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: Bumper numbers
Originally Posted by station View Post
What are the rules regarding colors on the numbers for the bumpers.
R28A - 4" tall, .5" stroke and white or outlined in white.
Academic Student (Forever)
Unread 16-05-2016, 15:07
Billfred's Avatar
Billfred Billfred is online now
Re: Bumper numbers
R28.
Hasn't changed in a few years (2012, I think?). Might change next year. Read the manual then too.
Unread 16-05-2016, 15:09
scca229 scca229 is offline
FTA acquiring knowledge
AKA: Nate
FRC #0060
scca229 will become famous soon enoughscca229 will become famous soon enough
Re: Bumper numbers
Game Manual Section 4.7, BUMPER Rules, R28:
Team numbers must be displayed and positioned on the BUMPERS such that an observer walking
around the perimeter of the ROBOT can unambiguously tell the Team’s number from any point of
view and meet the following additional criteria:
A. consist of numerals at least 4 in. high, at least ½ in. in stroke width, and be either white in
color or outlined in white
B. must not wrap around sharp corners (less than 160 degrees) of the FRAME PERIMETER
*emphasis mine
Blue box for R28 says that the numbers can be split across sections of bumpers but must still be clearly visible and unambiguous.
{and sniped because I took waaayyy too long to type}
Nate
Last edited by scca229 : 16-05-2016 at 15:10. Reason: Apparently I take too long to type today....
Unread 16-05-2016, 15:21
rtfgnow rtfgnow is offline
AKA: Alex Tannahill
rtfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond reputertfgnow has a reputation beyond repute
Re: Bumper numbers
Originally Posted by Billfred View Post
R28.
I'm pretty sure it was different in 2015.
- Arizona North
Unread 16-05-2016, 15:28
Billfred's Avatar
Re: Bumper numbers
...d'oh.
Unread 16-05-2016, 15:54
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Bumper numbers
We always embroider our numbers (2015 excepted ). The last few years, a team mom had the machine, before that we sent them to a local embroider shop. They look great and hold up well. Actually we made an extra set in 2014 for 2015. So we are the ones responsible for no bumpers in 2015.
If you don't know what you should hook up then you should read a data sheet
Unread 16-05-2016, 16:03
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Bumper numbers
The 2016 rule was:
Originally Posted by R28
Team numbers must be displayed and positioned on the BUMPERS such that an observer walking around the perimeter of the ROBOT can unambiguously tell the Team’s number from any point of view and meet the following additional criteria:
  • A. consist of numerals at least 4 in. high, at least ½ in. in stroke width, and be either white in color or outlined in white
  • B. must not wrap around sharp corners (less than 160 degrees) of the FRAME PERIMETER
The bumper rules (as with all of them) are subject to change from year to year, but the 2012-2014 team number marking rules were very similar if not identical to 2016. ('5 is right out!)
