Go to Post "We just fundraised $5000 for registration, and you spent it all on balloons?" - [more]
Unread 20-05-2016, 17:58
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Histogram of # years active for teams that have dropped out
Originally Posted by Chris Hibner View Post
That distribution looks very "Weibullian", which is what I would expect. It's always cool when that happens.
Yes. Based on the (invalid) assumption that teams don't revive, the "mortality rate" between years 1 and 2 is 13-14%. (I used the data posted in the sustainability thread.) A bit of curve fitting indicates that the mortality rate declines by about 15% of its value each year. After year 9 there's a lot of scatter in the data, but the trend still looks good.
Unread 20-05-2016, 21:42
cbale2000's Avatar
AKA: Chris Bale
FRC #5712 (Gray Matter)
The results I got were similar, though the averages take into account older teams which plays with the values some.
The overall trend looks about like what you're describing though:
Unread 23-05-2016, 11:23
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Quite. I began by dropping all of the teams founded prior to 2000. There are many teams which no longer exist which do not show up in TBA at all. Maize Craze was reportedly played by 28 teams, but there are only 8 teams listed as having been founded in 1992, seven of which still compete. The survival rate of 1992 teams is therefore more like 25% than 87%. Dropping 1992-1999 was a bit arbitrary, but looking at your curve, I probably should have dropped a couple more years.
Unread 23-05-2016, 12:45
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
I'm pretty sure TBA will only return teams that survived into the static team number age (teams that folded before that wouldn't have been available in the FIRST records for TBA to import, and any data that did exist wouldn't have made much sense). So the cutoff would be: all teams on TBA competed in at least the 1998 season.
I couldn't find any quick examples to dispute that, although I didn't to an exhaustive search.
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 23-05-2016, 13:13
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I found a few, including 98, which only shows up in 1994; TBA does not even have a name for FRC98. Match scores are only present in TBA from 2002 forward, so I speculate that any team which did not win any awards and folded before 2002 is not represented. (FRC98 won rookie all star in '94).
