Go to Post To have respect for the process you are in right now, respect the knowledge around you by using it to your full advantage. - Scott Ritchie [more]
Unread 23-05-2016, 13:13
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Histogram of # years active for teams that have dropped out
Originally Posted by plnyyanks View Post
I'm pretty sure TBA will only return teams that survived into the static team number age (teams that folded before that wouldn't have been available in the FIRST records for TBA to import, and any data that did exist wouldn't have made much sense). So the cutoff would be: all teams on TBA competed in at least the 1998 season.
I couldn't find any quick examples to dispute that, although I didn't to an exhaustive search.
I found a few, including 98, which only shows up in 1994; TBA does not even have a name for FRC98. Match scores are only present in TBA from 2002 forward, so I speculate that any team which did not win any awards and folded before 2002 is not represented. (FRC98 won rookie all star in '94).
