Go to Post Set your goals as high as your team thinks they can achieve (drafted, drafting, win awards, regional champs, world champs, etc) and go for them. Let the chips fall and have no regrets. - BPetry234 [more]
Unread 24-05-2016, 13:51
NShep98's Avatar
NShep98 NShep98 is online now
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is on a distinguished road
Re: pic: FIRST FRC Participation
Originally Posted by Lil' Lavery View Post
Can anyone provide insight as to what happened in 2004/05? Did some grant project fund rookies then stop support?
My guess is a significant source of funding for FRC stopped entirely. On TBA's Insights page (http://www.thebluealliance.com/insights) 2005 is the only year in which there was a drop in the number of matches, by at least 1000 at that. And less matches fewer teams and/or events.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 24-05-2016, 14:20
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Not only was there little growth (the attrition and rookie curves practically touch, and the total number of teams is flat), this was the year that the game format went from 2v2 to 3v3, presumably accompanied by a reduction in the number of matches played at each event.
Unread 24-05-2016, 14:29
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Is the 2010-2011 bump in rookies due to the JCPenny grant? I can't remember when that began/ended. Know there were a ton of teams that took advantage of that.
Edit: That's when Districts began in Mich, right?
$1000 bump in registration is pretty big. Were rookies always $1000 more than vets or when did that start?
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 24-05-2016, 14:30
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Thanks, Karthik.
A number of 2005 events are missing match results on TBA. That's the culprit.
The first season of the district format in Michigan was 2009.
I believe the differentiation between the "rookie kits" and "veteran kits" began in 2010 (the second year of the cRio). For most of the duration of the IFI controller, all teams got a new control system each season.
