Re: paper: Einstein History
Yes, you are right. TBA had only the data for the winners and finalists for 2001 and 2000. I will add the data right now. I would also appreciate it if someone could provide the 2000 semifinalists data.
33 should have a win too with 233 and 2056
Surprised to see that Ontario (54) and New Jersey (51) are so close. Ontario has a larger population, so its not at a disadvantage. Michigan is only a bit bigger than NJ but scores 170.
Code:
State Population/Score MI 58,293 CT 71,934 DE 116,952 NH 132,681 NV 141,955 NJ 175,258 IN 188,482 AR 249,507 CA 253,611 ON 255,409 MA 281,059 IL 292,740 NOR 339,650 OH 362,318 AZ 517,806 RI 527,587 NY 598,371 TX 599,044 FL 621,666 HI 709,781 SC 805,414 QBC 826,360 VA 832,629 NC 903,997 MN 909,529 PA 913,372 WI 959,594 CEN 1,012,250 MS 1,492,463 ID 1,634,464 TN 1,637,338 WV 1,850,326 OR 1,985,120 ALB 2,098,250 GA 5,048,672 MO 6,063,589 WA 7,061,530 NSW 7,500,000 |
I'm proud of my little state...
In terms of general population, yes, Michigan is only a bit bigger than New Jersey. In terms of team count, Michigan boasts more than five times as many teams as NJ (411 vs 76).
Thanks for the data!
Just a quick note, 694 is from New York, not Ohio. |
The worksheet has them down as from NY. I think you may have accidentally saw the row above them, 610 who are from ON.
111 has won 3 championships, including 2003. Looks like the data from 2003 on TBA is... not quite right.
The page on FIRST is not responding for me to check the source. |
#10
For 2003, both alliances are listed as finalists on TBA, and no winner. Should I switch that to both alliances as winners, or keep them this way?
#11
Awesome work Mark! It's fun to pass the time looking at this data and analyzing for my own conclusions!
#12
http://www.thebluealliance.com/event/2003cmp#awards 2003 is also missing the SF teams: 236, 341, 175, 378, 292, 302 |
#13
You may be interested in comparing your data against this: https://www.chiefdelphi.com/media/papers/3263
#15
