Go to Post Ha. Lavery's a genius. - Aignam [more]
Unread 13-06-2016, 00:07
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Bearing Reamer?
Has anyone experimented with using a carbide 1.125 inch bowl and tray router bit as a final pass on your bearing holes when using a CNC router? Like the one below, thoughts? Any idea on the tolerances on a bit like this one?
http://www.amanatool.com/products/ro...nch-shank.html
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 13-06-2016, 00:17
AnthonyDV AnthonyDV is offline
FRC #1678 (Citrus Circuits)
AnthonyDV is just really niceAnthonyDV is just really niceAnthonyDV is just really niceAnthonyDV is just really niceAnthonyDV is just really nice
Re: Bearing Reamer?
A combination of the motor not having enough torque, a low enough rpm, and the router not being rigid enough means the reamer would chatter alot. We have had success making our holes around .015 inch undersized and reaming them out on a drillpress.
Unread 13-06-2016, 00:20
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Bearing Reamer?
Originally Posted by AnthonyDV View Post
A combination of the motor not having enough torque, a low enough rpm, and not being rigid enough means the reamer would chatter alot. We have had success making our holes around .015 inch undersized and reaming them out on a drillpress.
Ditto
We had some custom reamers made a while back. We go .015 to .01 undersize and then ream (press fit thanks to custom sizing )
R.C.
MadTown Robotics Team 1323
Unread 13-06-2016, 00:38
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: Bearing Reamer?
For anyone curious, this is the reamer we bought off ebay. We got two of em and they've been great. We are lucky that our Drill Press spindle and Clausing Lathe tailstock both have Morse Taper #3, so we can use the reamer on both machines effortlessly.
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 13-06-2016, 23:50
teslalab2's Avatar
teslalab2 teslalab2 is offline
RogueBotix LLC
VRC #8091
teslalab2 will become famous soon enoughteslalab2 will become famous soon enough
Re: Bearing Reamer?
As a machinist, I would recommend an offset boring tool. You could put it in the drill press and then bore any sized hole you would like.
I need a jaguar development board for reprogramming a jaguars bootloader. if you have one that you want to sell, pm me. thanks
Run you CanJaguars on arduino with ArduRIO, you can also easily control Talons, Victors,Jaguars and Sparks on PWM. https://sourceforge.net/projects/ardurio/
Unread 13-06-2016, 23:54
Re: Bearing Reamer?
I used to use an offset boring head, but after a couple years I got (extremely) lazy, especially because switching to the boring head required me to drop the knee of the mill 3" or so. Now we use positive bearing retention everywhere and 1.125" holes.
My method is to drill with a 1/2" drill first (largest one we have), then go in with a 3/4" then 1" endmill. After that I finish up the hole with a 1.125" endmill. This gets some tight slip fits and a very round hole.
My dream is to own a 1.124" reamer, but the $200 cost for a custom one doesn't suit me too well. Given that we use a manual mill anyway, it doesn't hurt to use the 1.125" endmill we already own.
Unread 14-06-2016, 14:41
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Re: Bearing Reamer?
Im not sure if this is the exact model we have but this is what my team uses. We spent some time last offsetting setting it to exactly 1.124 and we never change it. The CNC router gets us to 1.12 ish and we manually clean it up with this:
http://www.mscdirect.com/product/details/02239093
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 15-06-2016, 11:26
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
Re: Bearing Reamer?
I got my 1.124" reamer for $52 shipped on eBay. Brand new. Keep an eye out for them!
Unread 15-06-2016, 14:52
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bearing Reamer?
That bit is NOT a reamer, and don't count on the tolerance to be down to 0.001".
As others have said: make the hole several thousandths undersize and use a hand reamer to make it half a thousandth (or so) undersize.
EXPERIMENT in the off season!
Unread 16-06-2016, 02:00
Re: Bearing Reamer?
Boring heads are great when used on a mill, but there is no good way to use one on a drill press. There isn't really a good (safe) way to hold your work or locate the center of a hole. The spindles in drill presses are not designed to take the unbalance load from a boring head.
Unread 16-06-2016, 02:43
Munchskull's Avatar
Munchskull Munchskull is offline
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: Bearing Reamer?
Another option is to ream it to 1.125 and then use locite designed for beating retention.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 16-06-2016, 21:50
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Re: Bearing Reamer?
You could also polish a 1.125 drill or mill slightly under sized on a lathe with Emory paper. (Run the lathe in reverse). Taking off 0.0005 should be easy with HSS.
Lapping compound is another option.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 17-06-2016, 21:46
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Bearing Reamer?
If you can chuck it in a lathe, you can bore it to half a thousandth with some care.
Unread 18-06-2016, 11:59
InFlight's Avatar
Re: Bearing Reamer?
An experienced mentor machinist with a Starrett micrometer can achieve half a thousand on a nice big lathe that well is adjusted.
An above average student machinist on a mini-lathe using $15 digital calipers would be good to hold 0.002".
My point was either end of the machinist spectrum could take a 1.125 mill or drill and undersized it enough to achieve a snug R8 bearing fit.
Unread 18-06-2016, 21:14
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Bearing Reamer?
I don't think that this is what you're looking for, but we used this step drill bit to clean up bearing holes in our waterjetted pieces this past season. It can put a 7/8" OD hole into 1/8" thick material, or run through thicker material with a 1.125" OD hole. Just the right size for the 3/8" and 1/2" bearings we all use.
http://www.mcmaster.com/#8841a35
Step drills are cheaper than reamers, but they can wander if you are taking off a lot of material. Our gearboxes worked great, but we had padded in an extra .003" between adjacent bearing holes to prevent gears from binding if things were off. If you want tighter tolerances, you probably don't want a step drill.
