Go to Post your bot brings all the boys to the yard. - looneylin [more]
Unread 17-06-2016, 23:59
Scott Kozutsky's Avatar
FRC #0865
Re: pic: OmniSwerve chassis Bottom View and Concept Discussion
Originally Posted by Dan_Karol View Post
Maybe i'm missing something, but how does it turn?
If all pods are ganged together then you have no control over what your heading is or you have no ability to strafe.
The way I have it is they all point in the same direction. You can tank turn in any orientation by simply driving one side forward and one side back. Only the pivots are chained together not the actual drive.
The reason you can't turn in conventional crab is because the drive is all chained together and because the wheel scrub from trying to tank turn is too significant.
here's a crude vector diagram of my 3 wheeled swerve rotating.
http://imgur.com/0HMYj0g
If they were traction wheels the steering would be awful (non existent) because the wheels would oppose the lateral forces exerted on them. With omni wheels this does not happen so it should be able to turn quite nicely.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
