Go to Post I used to think FIRST was about my learning experiences, but now that I'm out of high school and am a seasoned veteran of FIRST I've realized that this organization is about more than my own enjoyment, it's about the enjoyment of others. - Jeremiah Johnson [more]
Unread 06-18-2016, 01:07 AM
Scott Kozutsky's Avatar
FRC #0865
pic: OmniSwerve Pivot Top View
Unread 06-18-2016, 01:08 AM
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Re: pic: OmniSwerve Pivot Top View
Maybe I'm missing something, but what's holding the CIMs in place?
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 06-18-2016, 01:10 AM
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
Friction. It appears to be a clamping design (look at the standoffs).
Unread 06-18-2016, 02:00 AM
Division by Pirates
That's what I assumed. Is this actually a design that teams use? I don't know if I could ever trust it.
Unread 06-18-2016, 02:29 AM
I think I remember a team using it at champs last year, but I don't recall which one. They had a few different revisions of swerve drives. The CIM was in a swerve drive module and had one end clamped in place.
I would feel safer if the CIM was clamped on the front and back endcaps instead of the black body, but as a concept I think it can work.
Unread 06-18-2016, 06:48 PM
Joey Milia's Avatar
FRC #0192 (GRT)
Yeah I would be worried about CIM diameter tolerances and the effect they would have on the gear mesh. Clamping on the aluminum ends might work but the rubberized black body is probably too variable.
Unread 06-19-2016, 02:48 PM
FRC Alumnus
FRC #1768
Rubberized?
Unread 06-19-2016, 03:31 PM
FRC #0865
Rubberized?
The casing probably isn't adequately concentric with the shaft so the gear spacing could be pretty significantly off. That said, peoples get away with 10-32 screws in loose fit holes for gear spacing on drive gearboxes (when they don't use the flange for more precise centering). It might take a little finicking but I think it's certainly doable to use a clamp like this. As I understand it, gears can handle pretty significant misalignment if they aren't expected to run for very long.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 06-19-2016, 03:45 PM
FRC Alumnus
FRC #1768
I agree with everything you are saying, I'm just confused by the term "rubberized."
Unread 06-22-2016, 12:54 AM
Joey Milia's Avatar
FRC #0192 (GRT)
Rubberized?
I believe the black portion of the CIM is steel with a black rubber coating on the outside, thus my use of rubberized.
The problem isn't the lack of concentricity, the outer casing isn't spinning so it doesn't matter. What does matter is the very loose tolerance (only max is stated, not an actual tolerance) on the outside diameter that you're clamping onto. If you assume nominal is 2.5" and max is +36 thou thats quite a large tolerance. However if you were to measure all of your cims and find them all to be the same then you could probably get away with it and be fine.
EDIT: ok concentricity kind of matters but becomes kind of irrelevant once you clamp the motor down. And lack of it could even be used to adjust the center distance to correct it.
Unread 06-22-2016, 02:59 AM
DaveL DaveL is offline
FRC #2976
This is a great design!
I like that its compact, has a lot of power and uses a wide base of support.
Like others have said, mounting the CIMs to their faced plate is the tried and accepted way to go, but I like the way you are thinking.
I am a little surprised you went with omni wheels. My guess is that they won't have the friction to transfer the power of the CIMs during high acceleration. Changing to a tread wheel would fix that. If you are short on resources, build one module and mount it up front. Then independently power the non-steering rear wheels. That would be one fun trike. For more fun, add omni wheels to the rear so you can slide your turns.
Unread 06-22-2016, 10:01 AM
I don't really see the benefit of clamping the CIM versus just face mounting it to the outer plate with a clearance hole on the inner plate. It's a little more compact I guess.
Clamp mounting the CIMs is something that does work, but I've never done it where the clamping action is used to hold a gear mesh together. In 2013 my old team mounted CIMs to a Frisbee shooter by clamping on the outside and it held all season, but there were no gearboxes to worry about.
Unread 06-22-2016, 01:00 PM
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Are we all ignoring the fact that this is a swerve drive with omni wheels?
Might I ask the obvious question: why swerve with omni wheels?
Unread 06-22-2016, 01:06 PM
Another thing - I don't really like the lightening pattern on the gear. The spokes don't do a ton for the gear's strength, and a spoked lightening pattern like that requires milling whereas a no-spoke lightening pattern could potentially be turned.
If you are going to do a spoked lightening pattern, at least make it six spokes and have the spokes align with the hex points. That way the additional material is behind the stress risers and not just in random places.
In either case, I would leave a bit more material around the hex (maybe .875 diameter?). The material left around the gear teeth should be fine. If the thin part of the gear is at least .15 thick or so you should be fine. These are "gut numbers" not backed up by real math or engineering, just experience, so take them with a grain of salt.
Unread 06-22-2016, 03:51 PM
Aren_Hill's Avatar
Build Nifty Things
The CIM sleeve is just black gloss powdercoat, there are rubber seals between the sleeve and the endcaps.
-Aren
A guy who likes robots.
