Go to Post Remind me again. Why do we let the GDC hold us captive to these hints year after year? - jholman [more]
Unread 06-22-2016, 04:10 PM
Scott Kozutsky's Avatar
FRC #0865
Re: pic: OmniSwerve Pivot Top View
Another thing - I don't really like the lightening pattern on the gear. The spokes don't do a ton for the gear's strength, and a spoked lightening pattern like that requires milling whereas a no-spoke lightening pattern could potentially be turned.
If you are going to do a spoked lightening pattern, at least make it six spokes and have the spokes align with the hex points. That way the additional material is behind the stress risers and not just in random places.
In either case, I would leave a bit more material around the hex (maybe .875 diameter?). The material left around the gear teeth should be fine. If the thin part of the gear is at least .15 thick or so you should be fine. These are "gut numbers" not backed up by real math or engineering, just experience, so take them with a grain of salt.
The design assumed use of a CNC router so that would be used to do the pockets (multiple passes, depth of cut isn't that great but its certainly doable). I also made sure not to pocket it all the way through so there is 1/16 of material left on the bottom which should adequately handle the torsional shear between the hex and the teeth. The diameter of material surrounding the hex is .8 which should be ok as there will be relatively less stress acting on it (3.25in omni wheels can only transmit so much torque compared to 4 in nitrile for example). 7 spokes is a byproduct of our team name, not the best engineering solution but we'd probably keep it anyways.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
Unread 06-22-2016, 04:18 PM
FRC #0865
Originally Posted by JamesCH95 View Post
Are we all ignoring the fact that this is a swerve drive with omni wheels?
Might I ask the obvious question: why swerve with omni wheels?
Various Reasons
Unread 06-22-2016, 09:19 PM
Cothron Theiss's Avatar
Have you run any simulation or FEA to confirm that this gear won't fail? Also, have you designated a material for the gears? (I apologize if you've already listed he material and I just missed it.)
Unread 06-22-2016, 11:04 PM
FRC #0865
I haven't run FMEA as it's not a design I really plan on using but they're 7075-T6 vexpro gears.
