Go to Post You should never, EVER bully, manipulate, or slander another team for the sake of winning. - Libby K [more]
Unread 22-06-2016, 11:26
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
pic: 2x 15mm HTD Belt Pulley
Unread 22-06-2016, 11:32
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
1493kd will become famous soon enough
Re: pic: 2x 15mm HTD Belt Pulley
I am guessing this is going to be used for belts in tube drive.
Is the countersink to let the bearing rest inside of the pulley and not need any spacing away from the tube ? We have done that the last 2 years and it works out great. The bearings help hold the pulleys in place while you set all the belts in and hold them in place with hex shaft. Once in place we have not touched it or made any adjustments the last 2 seasons.
Unread 22-06-2016, 11:35
Robotics Engineer
The countersink is to get around the bearing so I can fit 15mm belts inside 1.5" tube.
See this post: https://www.chiefdelphi.com/media/photos/43873?
Unread 27-06-2016, 11:46
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Neat concept - worth trying out. Where would one get 5mm HTD pulley stock?
Unread 27-06-2016, 13:31
Robotics Engineer
https://shop.sdp-si.com/catalog/?brand=sdp&cid=p345
You can get GT2 pulley stock too, which is compatible with GT3 belts. GT3 belts, while more expensive, are twice as strong as HTD belts of the same size.
You can check out that discussion here: https://www.chiefdelphi.com/forums/s...hreadid=149109
Unread 27-06-2016, 13:43
If you're already going to SDP-SI for pulley stocks, might as well go for GT2 pulleys and GT3 belts.
