Go to Post At least I can appreciate the humor in this LOLCODE; it isn't funny when our our robot goes backwards in hybrid mode - sgreco [more]
Unread 04-07-2016, 12:42
S.P.A.M.er 17's Avatar
S.P.A.M.er 17 S.P.A.M.er 17 is offline
Mentor (4118), Alumni (180)
AKA: Ralph,Ralf,Raph(I can't spell)
FRC #4118 (Roaring Riptide)
S.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond repute
Re: pic: Offseason Shooter CAD Project
Is the pulley on the side for vertical aiming? Also, How thick are your blue plates, and what tap size did you use to secure the pulley plates? Do you see any potential problems with drilled out holes that are almost as big as the thickness? I've never done something like that, so I'm just curious.
Doing stuff for robots: just as hard as doing robot stuff.
Unread 04-07-2016, 13:08
Sperkowsky's Avatar
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Yes, the pulleys on the sides are for tilting the shooter.
The plates are 1/4" thick. I am going to tap for 10-24 bolts which require a hole of .1495. A 10-24 screw is .190" in diameter. So, it does leave a decent amount of space left. Thinking of the failure mode I have a hard time seeing them fail but again I can not be 100% sure unless I tested it.
