Go to Post But now we know what's inside Shaun's backpack! ...Don Rotolo's plastic egg. - MishraArtificer [more]
Unread 06-07-2016, 11:43
Re: pic: GEAR & CHAIN IN TUBE 8WD
Originally Posted by Ty Tremblay View Post
Using the tube to keep chain on is sub-optimal. In my opinion, you shouldn't use anything other than proper tension, power transmission, and tooth engagement to keep a chain on the sprocket. If you design the c-c spacing properly, the chain shouldn't get loose enough to jump off sprockets as it wears in.
It's just that I've built a bunch of chain drives at exact center distance, using sprockets of a variety of different sizes and under different loads, that have stretched to the point of jumping off sprockets. Everything is properly aligned, it's just from wear. I've always been told the "magic" of chain-in-tube is the tight fit prevents a loose chain from jumping, since it has nowhere to go, but maybe I just have bad chain runs or something.
Unread 06-07-2016, 12:06
Cothron Theiss's Avatar
I agree that exact c-c is a viable option, and having the chain stay on because of proper tensioning and spacing is preferable, but I think having a tight fit inside the tube adds an extra measure of safety in preventing failures. Hopefully this would be redundant, and the tube would never need to keep the chain on the sprocket, but taking advantage of this peace of mind is one of the benefits of running chain in tube.
