Re: pic: GEAR & CHAIN IN TUBE 8WD
Sorry, couldn't get to my computer until tonight.
![]() Quote:
I do agree that this chain setup is not ideal, but I kind of got worked into a corner with trying to fit everything in the tube. I am working on a variation right now with smaller wheels, and a 2" height tube, and am attempting to have the entire chain run inside the tube. The challenge there is you have to choose between: (1) Motor clump on the corner wheels which for everything to fit means that your wheel is pushed further in from the front/back of the chassis so the CIM can sit in front (2) Motor clump in the middle and your tube gets wider to accommodate both sprockets on the wheel shaft and the gear. I keep going back and forth on which I'd prefer. May end up designing both and seeing how they both look as an end result. |
Here is the updated version I ended up with.
-23.33lbs, only parts missing are chain runs, and bumper supports I suppose (all hardware besides rivets included) -24"x32" chassis -4"x1.5" VEX Colson wheels (1/2 hex bore) -11:70T Single Stage reduction within the drive tube -Drive tubes are 2x2x.125" 6061, while the front and back tubes are 2x1 Versa -All sprockets are 16T #25 VEX sprockets with the chain run fully contained inside the tube -The middle wheel is dropped 1/16" -In this current configuration a US Digital S4T encoder is utilized, though the CIM encoders could easily be used instead, or a Grayhill, etc. -All parts are COTS except for the two drive rails, the two encoder plates, and the belly pan (could be lexan, wood, etc. for low cost) -The only other modified parts are the front and back rails (lightening pattern), shafts cut to length, and the direct drive shaft is turned down on one end to 3/8" round to couple to the s4T encoder (optional depending on encoder use) Apologies again for the large picture: ![]() |
After initially dismissing the idea as "sketchy" because of the integrated gearbox, after looking at the lower custom part count and the resulting reduction in cost, I think this is a great idea for making a custom chassis at a low cost and weight.
I don't like your lightening patterns, but apart from that the design looks great. The dual versagussets in the corners really stand out to me as a feature of 2x2 tubes. Do you think it's possible to make a shifting version? Can all the gears + sprockets fit? |
