Go to Post Some things in life are far more important than Robotics. - IMDWalrus [more]
Unread 10-07-2016, 03:12
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
Re: pic: GEAR & CHAIN IN TUBE 8WD
Here is the updated version I ended up with.
-23.33lbs, only parts missing are chain runs, and bumper supports I suppose (all hardware besides rivets included)
-24"x32" chassis
-4"x1.5" VEX Colson wheels (1/2 hex bore)
-11:70T Single Stage reduction within the drive tube
-Drive tubes are 2x2x.125" 6061, while the front and back tubes are 2x1 Versa
-All sprockets are 16T #25 VEX sprockets with the chain run fully contained inside the tube
-The middle wheel is dropped 1/16"
-In this current configuration a US Digital S4T encoder is utilized, though the CIM encoders could easily be used instead, or a Grayhill, etc.
-All parts are COTS except for the two drive rails, the two encoder plates, and the belly pan (could be lexan, wood, etc. for low cost)
-The only other modified parts are the front and back rails (lightening pattern), shafts cut to length, and the direct drive shaft is turned down on one end to 3/8" round to couple to the s4T encoder (optional depending on encoder use)
Apologies again for the large picture:
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 10-07-2016, 03:19
After initially dismissing the idea as "sketchy" because of the integrated gearbox, after looking at the lower custom part count and the resulting reduction in cost, I think this is a great idea for making a custom chassis at a low cost and weight.
I don't like your lightening patterns, but apart from that the design looks great. The dual versagussets in the corners really stand out to me as a feature of 2x2 tubes.
Do you think it's possible to make a shifting version? Can all the gears + sprockets fit?
