Go to Post [Goals For 2012] 1. Build on 20 years of hard work. 2. Inspire a new generation so they come back another year. 3. Repeat. - Koko Ed [more]
Unread 10-07-2016, 16:12
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Re: pic: GEAR & CHAIN IN TUBE 8WD
Originally Posted by pwnageNick View Post
Well in this specific situation the top half of the chain runs inside the tube while the bottom half of the chain runs under the tube. So using masterlinks the chain would be easily accessible and easy to switch. Maneuvering around the sprockets should be fine with the access slots on the bottom of the tube.
Have you run a chain below tube/drive chassis/bellypan like this before? Do you run into issues with getting carpet junk into the chain or having the chain exposed to accidentally being hit on things? I am curious because we are considering running a similar chain setup, but don't have much relevant experience to base off of.
