Go to Post Brandon Martus, making CD readers' lives easier since May 2001/Fall 98 - Beth Sweet [more]
Unread 10-07-2016, 20:08
Re: pic: ABS-122, shifter-in-tube chassis
Originally Posted by Cash4587 View Post
It doesn't look like you have any form of chain tensioners on this setup. Although you can do without them, I would still really recommend putting them on even in the case of using large tooth count sprockets. We used a setup similar to this in terms of chain, and really wished we had designed a way to tension the chain during the season.
We used 16t #25 sprockets all season with only a single jump at SVR (and that was after another competition in Utah) and that was after the chain got very loose. It's possible to add tensioners in the form of versablocks or even WCP sliding bearing blocks, but I like the set-and-forget of direct C-C. Are you certain that your sprockets were correctly aligned? I'm guessing that they were and you guys just did much harder driving than us, but it never hurts to check.
With massive sprockets such as these I'm not as worried about the chain coming off as much as I am about the chain picking up tape. I could swap these out for #35 chain sprockets, but the extra weight isn't worth it to me. In-season if it became a problem switching to #35 chain would be my first choice.
