Go to Post Well, we put it in the bag at 11:58 last night. Needless to say we had to pull guys off of it to put it in the bag. I hope we didn't miss somebody and bag him up too. - jimwick [more]
Unread 11-07-2016, 21:56
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Re: pic: ABS-122, shifter-in-tube chassis
I see, that's a good reason to run proper tensioning.
How did it cause errors/to what extent? If two wheels are moving, theoretically the whole bot should move anyway. Would direct driving the center wheel help?
So this year our robot had about 60% of our weight on the front wheels. Direct driving the center wheel or any wheel might have helped. We ran a single gear reduction 12-66t and then a 12-22 #35 chain reduction to the wheel. (We later switched from 12-22t to 12-28t and is much better) In our case, direct driving any wheel may have helped but we really enjoyed this setup. We would get no movement on our robot for about 1/8th of a turn on the back wheel to catch up in chain slack. The whole robot wouldn't move because we had tons of turning scrub also so I guess a few things would have helped. But in any case, the chain slack and slop in the hex shaft really was a pain when trying to tune our code. I guess that's why 971 goes through so much to get all of the slack out of everything and makes custom hex.
