Re: pic: Everything in the tube drive (too late to turn back now)
When you expand the drive rails to 2"x2" (which is my educated guess as those rail dimensions), how much space are you actually saving by going in tube?
Any reason you put the outer wheels on the inner edge of the tube and not the outside? Having them on the outside reduces turning scrub (slightly) and lets you extend your belly pan into the corners of the frame.
Though, having a hexagonal frame perimeter might make it easier to avoid pins. |
My apologies for the slow response. I just got off work.
Have you ever used this technique in real life? Even if you have a facing cutter and a good size mill it would take a huge amount of time and resources. The same result could be achieved by bolting/riveting/epoxying/welding a reinforcement plate in the areas you need on some thinner wall tubing.
In general when working with square tubing it's a better use of resources to order a smaller size/wall thickness than to machine weight away from a thicker tube. Last edited by 42! : 13-07-2016 at 03:39. |
Could I get a picture of your shifter shaft without any gears on it? Kind of curious how that works out, with the pulleys on either end and the shifter in the middle.
Would you be able to put your front and back wheels inside the rails as well? That would utilize more space in them and maybe make the concept more valuable with as much space as possible being utilized
Here's the updated model:Picture |
Code:
1.25*sin(x)=1 sin(x)=0.8 x=arcsin(0.8) L=1-1.25cos(x) //maximum length of remaining material (in inches), measured from L=0.25 //edge of tube, assuming motor is centered |
#10
On a slightly more serious note, there is still unused space in the front and back rails for possible manipulator or slide drive mechanisms. Last edited by PAR_WIG1350 : 15-07-2016 at 22:18. Reason: More to say, didn't want to make consecutive posts |
#12
