Go to Post For me Gracious Professionalism is about helping other teams make their ideas work. We do everything we can to help other teams program, or lend them parts from our pit. On the field we play to win. - Alpha Beta [more]
Unread 12-07-2016, 23:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: ABS-122, shifter-in-tube chassis
On the other hand, if 60% of my robot's weight were on the front wheels in a static configuration (and presuming I had at least six wheels), I would be VERY worried about the robot falling on its face in a braking maneuver.
Originally Posted by MichaelBick View Post
That is completely dependent on CG height and, given 4587's short robot, probably not a major risk.
I know it sounds strange, but if this is the case, I would seriously consider not driving the back wheels at all -- save the chain and sprockets and heartache. I might even consider skipping the back wheels and putting some pegs or furniture gliders. Here's why: If 60% of the weight is on the front wheels, the CoG is closer to the front wheels than the middle wheels. If the CoG is low enough that you are "not at major risk" of braking hard enough to tip forward, you are probably "at minimal risk" of ever needing to put weight on the rear wheels, and at "fuggetaboudit" for need to drive those rear wheels.
