Go to Post Part of Gracious Professionalism is the Professional bit. Doesn't matter if you're a volunteer or a staff member, a failure of this level in the real world would result in getting fired. - [more]
Unread 13-07-2016, 01:13
FRC #1836 (MilkenKnights)
Re: pic: ABS-122, shifter-in-tube chassis
I know it sounds strange, but if this is the case, I would seriously consider not driving the back wheels at all -- save the chain and sprockets and heartache. I might even consider skipping the back wheels and putting some pegs or furniture gliders. Here's why: If 60% of the weight is on the front wheels, the CoG is closer to the front wheels than the middle wheels. If the CoG is low enough that you are "not at major risk" of braking hard enough to tip forward, you are probably "at minimal risk" of ever needing to put weight on the rear wheels, and at "fuggetaboudit" for need to drive those rear wheels.
The major issue with this (for my team) is pushing matches: for example, during forward pushing you can easily have 100% weight on the back two wheels.
