Go to Post Tolerance, forgiveness, humor, and lessons learned are tools we can find here. - JaneYoung [more]
Unread 15-07-2016, 01:08
BotDesigner's Avatar
AKA: David Gedney
FRC #4418 (Team Impulse)
pic: Streamlined Basketball Drive
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Re: pic: Streamlined Basketball Drive
Wow this looks neat! My only concern is the CIM motors on the bottom. How will you wire them without the wires being crushed or the insulation melting from the heat of the motors?
Unread 15-07-2016, 01:13
I like the form factor a lot, but I'm seconding Ollien's comment. Expanding it out by 3/4" or so would fix the problem.
The use of 1 wheel for 2 balls is very clever, but you might want to spring load the casters to keep contact with the wheels as they wear down. The issue of "drilling" into the ball with an un-moving wheel is still there, but maybe if you used thinner wheels and something like a metallic ball you might have better luck.
EDIT: What's the FPS and weight?
Unread 15-07-2016, 03:34
cad321 cad321 is offline
AKA: Brian Wagg
FRC #2386 (Trojans)
I agree with the comment above about the wire spacing, however while were there, on the model posted to grabcad, it appears that the cims themselves are actually interfering with each other. The small round protrusion on the backs of the cims (~1in diameter) are going into the other cims by about 1/8in.
Unread 17-07-2016, 20:19
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
It's like the decagon wheel, single billet chassis robot... but actually buildable. Props, looks pretty $@#$@#$@#$@# neat.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 20-07-2016, 20:00
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
if someone actually builds this, i will hold you in awe forever
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 20-07-2016, 22:29
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The weight of the robot (excepting the basketballs) is supported by the downward-facing ball casters. Basketballs are typically pressurized to 8psi, so assuming the robot weighs 100 lb, you would need to apply that force over 3+ square inches on each ball. As the casters are not that large, the basketball would significantly deform at this point to bear the load, interfering with the drive-ability (though obviating the need for springs). Deformation would get worse under acceleration. I would consider stiffer balls, perhaps like asid61's suggestion of metal (or rubber over metal) ones, or at least larger load-bearing ball casters.
Edit: This would be even cooler as a kiwi; I think the forces would add up properly for rotation and translation, though less efficiently at the ball-carpet interface.
In either case, It appears that the inverse kinematic equations are to drive each wheel as though it were an omni, but in the opposite direction. Negative Killough/Mecanum for four-ball, negative kiwi for three-ball.
Unread 26-07-2016, 14:41
Lireal Lireal is online now
AKA: Alex Colello
FRC #2141 (Spartonics)
Could basketballs be replaced by a metalsphere, with some kind of coating for traction? Would a sphere like this work: http://www.kingmetals.com/Catalog/Ca...Id= 204&NSM=Y
If not, how thick would 8-10 in diameter steel spheres need to be to support the weight of a ~100 lb robot?
Unread 26-07-2016, 18:51
AKA: David Gedney
I think that would be a better way to go. As GeeTwo pointed out, the deformation in the basketballs is going to cause major problems with the driving.
I think the best way to "coat" the basketballs would be to cut some type of grippy material into hexagons and pentagons and glue them on like the ones on a soccer ball.
As for the strength of those steel spheres, I have no idea; you probably have to do some force calculations. They are most likely strong enough; I have played with some garden decoration spheres and they would appear to be able to support this.
2016, 2017 Colorado FLL Champions
2014 FLL North American Invitational, 1st place Strategy and Innovation Award
2014, 2013 Kentucky FLL Champions
2nd place Strategy and Innovation ward
FLL Team Automaticus Rex, Team Captain('11-'14) youth mentor ('15-'17) FRC Team 4418 Member ('14-') Design Lead ('15-16') Program Managment ('16-')
Unread 26-07-2016, 20:38
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
While gluing a dozen pentagons and a score of hexagons could possibly work, I was thinking of spraying pickup truck bed-liner or similar material onto a metallic spherical shell.
Unread 27-07-2016, 13:17
Data Nerd
FRC #0079
https://www.chiefdelphi.com/forums/s...12&postcount=9
Unread 27-07-2016, 14:53
AKA: Alex Colello
How would you do the calculations to determine if a hollow metal sphere is strong enough to support the weight of the robot?
Unread 19-09-2016, 16:51
Evan Scholl Evan Scholl is offline
AKA: Hello it's me
FRC #1625 (Winnovation)
Evan Scholl is an unknown quantity at this point
Thumbs up Re: pic: Streamlined Basketball Drive
I would put omnis instead of whatever wheels you currently have in because the friction is really going to deteorate both the ball(and also the omnis) whilst also causing slow movement
