Go to Post But as with all things: we shall see. - pfreivald [more]
Unread 15-07-2016, 11:53
chrisfl chrisfl is offline
FRC #1991 (Dragons)
chrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to allchrisfl is a name known to all
Re: pic: Everything in the tube drive (too late to turn back now)
Originally Posted by PAR_WIG1350 View Post
Now, what would it take to get the motors inside the tube? They are fairly high on the list of components that get in the way, so that should be a priority. (2.5" motors fit in 2" tubes, right?)
Code:
1.25*sin(x)=1
sin(x)=0.8
x=arcsin(0.8)
L=1-1.25cos(x)    //maximum length of remaining material (in inches), measured from
L=0.25            //edge of tube, assuming motor is centered
(Yes, they technically do.)
If you are really ambitious, I bet a few talons could fit in there too! Maybe an accumulator even.
1991 2015-present
Unread 15-07-2016, 22:10
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
While there are some that would fit, I think it would be more practical to keep the accumulators elsewhere. /S
On a slightly more serious note, there is still unused space in the front and back rails for possible manipulator or slide drive mechanisms.
Last edited by PAR_WIG1350 : 15-07-2016 at 22:18. Reason: More to say, didn't want to make consecutive posts
Unread 18-07-2016, 16:17
FRC #1991 (Dragons)
That would be a cool concept. A drop down slide drive with a full 6w tank. That'd be the ultimate butterfly drive! Have 2 omni wheels on the front and back faced perpendicular to the 6w tank. It'd be super heavy and complex though.
1991 2015-present
