Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Unread 15-07-2016, 17:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: SERGE: Shirt-Ejecting Robot for General Entertainment
Originally Posted by Cothron Theiss View Post
Yeah, I'd say the wheels the OP chose are by far the best for the situation, but it's something to consider. Can the swerve capabilities be disabled for driving on certain terrains?
Originally Posted by cbale2000 View Post
That would effectively turn it into a standard 4 wheel tank drive, which might actually be worse for turning due to the scrub it would induce than just staying with swerve enabled.
There are other possibilities - you could do an automotive or fire truck style steering setup, for example.
