Go to Post Also, I'm tired of the "FIRST is a simulation of the real world"-- it isn't. If the real world was like FIRST, there wouldn't be any need for this organization. - cadandcookies [more]
Unread 19-07-2016, 23:41
cad321 cad321 is offline
AKA: Brian Wagg
FRC #2386 (Trojans)
Re: pic: 25lb Drivetrain
Is there a reason you chose not to use bearing blocks on your drive wheels? Although I haven't built a WCD before, my understanding is that their benefits far outweigh the cons (the only con in this I could see is possibly weight as you're limiting it to 25lbs).
Unread 19-07-2016, 23:48
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
By removing the crossmember 2x1s in favor of the bent sheet metal you are saving a bit of weight. But it is not as strong and you are more limited in mounting points. The few pounds its saves is just not worth it imo.
Unread 19-07-2016, 23:54
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
A cross section of a C is almost negligibly weaker than a box. In this scenario, a single piece belly ban and front and back members is actually extremely rigid.
On top of that, a single-piece bumper could add even more strength.
By your logic, would not all drives with a similar single-piece belly pan and cross-members be weak, and limited in mounting? IIRC 971 uses a similar style design. What about the kit frame? It uses C-channel cross-members too.
EDIT:
Another reason for this design may be for maintenance.
With the one-piece belly pan and members design, you "cap" the end of your drive tubes, making it hard to change a chain in an (unlikely) emergency. Being able to pull bearings from the tube may allow you to slide a chain in without taking the belly pan off (even though it still sounds like a nightmare).
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 20-07-2016, 09:02
Putting bearings straight into 1/8" wall tubing is just fine, it's only 1/16" wall tubing you really have to worry about ovalizing with. You should be fine there.
I'd consider riveting the bearings in instead of screws, just because I hate 4/40 screws and breaking taps and stuff. I guess if you have to change out a bearing there will be some rivet scraps inside your tube and that's kind of nasty.
I agree that the one piece belly pan / C-channel member will make this chassis likely rigid enough to perform well, particularly with stuff on top of it, but I wouldn't say a C-channel is "negligibly weaker" than tubing. It's certainly got substantially less resistance to bending. In this case, it's somewhat offset by the fact that it's got a giant bottom flange connecting it to the other side, and that the C-channel hugs the inside of the drive tube. This style of drive has certainly been battle-tested before.
I think this drive would get some strength benefit from making the top flange longer. Just an inch long is a little wimpy as a C-channel, and it could kink in the middle if hit really hard (and the bumpers aren't backed up with their own frame etc). I would just extend the whole flange to the length that is present at the points where it attaches to the frame. You're already using that material anyway; what's another few ounces per side to resist bending on impact a bit better. Especially if the belly pan is .090.
Unread 20-07-2016, 09:51
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
I wouldn't even bother with holding the bearings in the tube. If you used screws and washers on the ends of the axles (or properly toleranced snap ring grooves) the bearings will have no where to go any way. 319 tapped the ends of our thunderhex shafts 1/4-20 and ran them all season without issues.
Unread 20-07-2016, 10:26
The bellypan design is quite interesting. If it were the basis for a kitbot, it would turn the kitbot frame into a 7-piece rivet operation.
It's like the AMU chassis found a way to become WCD.
GitHub
Unread 20-07-2016, 22:00
Meh, I've done it before. You don't miss out on much if the rest of the bot is planned out with enough attachment points. And the rigidity is there with the bellypan.
Unread 20-07-2016, 23:40
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I do like the concept, and the weight economy! It's designs like this that make me want the team to invest in a sheet metal brake, probably even ahead of a lathe. If we just had the space for some real shop machines (32'x24' for storage and workshop and programming and maybe everything else).
While c-channel is not as strong as tube (especially in torsion, and significantly in around the axis perpendicular to the "missing" face), I do not see this as a showstopper - as previously noted, the 2014-2016 kit bots used folded c-channel to rave reviews. (3946 purchased some 2015 frames on closeout that we plan to use in 2017, or in 2018 on the low-percentage chance that we decide to go another route.)
There is plenty of room for attachment points. The top of the front and rear rails, and the portions of the tube which do not have chain behind them can be perforated as needed.
I understand that chain-in-tube is usually "set it and forget it" over the course of an FRC season, but with the capped tube ends, this design does not seem to have a good way to swap out the chains if disaster should strike. As a first mitigation, I would probably NOT perforate the drive tube for mount points, but rather mount a c-channel or thick-wall tube of versa-frame in a location which would allow a side tube, wheels, chains, gearbox, and motors to be removed as a single unit without removing anything else but the bumpers, or design "everything but" the drive chassis and things mounted to the belly pan to be easily removable to allow drive rail removal and repair.
Finally, This was not a design point, but someone brought it up: I don't see how this could work as a kit frame. Kits usually ship in a box roughly 36" x 8" x 8", but this belly pan unit would have to ship as something rather larger. Even more critically, there is no good way to make this so that a team can select "long/square/wide" using a band saw. (And OBTW, the kitbots since at least 2012 have a LOT more options than are listed in the manual, if you are willing to put in a bit of skull work.) If you skipped the belly pan, much more is possible, but that misses the key feature that makes this such a weight saver.
Unread 21-07-2016, 08:16
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Man, if only boxes came in other sizes.
Unread 21-07-2016, 08:33
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Just because I'm curious and I've never worked with belly pans before, what advantages/disadvantages do they offer? I've heard that they add a whole lot of torsional stiffness to a chassis in a more weight-efficient way than a cross bar, but other than that I'm not sure.
Unread 21-07-2016, 08:34
Flywheel Police
Also gives you a place to mount electronics.
Unread 21-07-2016, 09:36
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
And in a game like 2016, they protect the bottom of your robot.
Unread 21-07-2016, 10:45
Deke's Avatar
Deke Deke is offline
no team (No Team)
Think of the belly pan like a bunch of strings or cables attached and tied everywhere at the base. It provides additional stiffness when the frame moves away from the belly pan and creates tension, but is very weak when in compression. Since it is attached all the way around, some part will always be in tension, providing more stiffness in the frame.
It is just one way of many ways to add stiffness to the frame. A disadvantage is that it is time consuming to make if you plan out all your electronics and place the holes for tapping and bolting then down. Also, depending on the rest of the frame members may not be necessary. In a case like this, where the frame members are light, the belly pan can give the stiffness needed to perform like a heavier drive train.
Unread 21-07-2016, 12:37
Flywheel Police
Using something like this allows you to create a bellypan very quickly and allows for flexibility in regards to electronics layouts.
Unread 21-07-2016, 12:43
In terms of easily laying out electronics, a perforated polycarbonate belly pan is an excellent choice. In terms of structural rigidity, a large thin sheet of polycarbonate is not ideal. Something like Baltic birch plywood would be a better choice for a combination of rigid, lightweight, and flexible for mounting electronics.
