Re: pic: 25lb Drivetrain
Just because I'm curious and I've never worked with belly pans before, what advantages/disadvantages do they offer? I've heard that they add a whole lot of torsional stiffness to a chassis in a more weight-efficient way than a cross bar, but other than that I'm not sure.
It is just one way of many ways to add stiffness to the frame. A disadvantage is that it is time consuming to make if you plan out all your electronics and place the holes for tapping and bolting then down. Also, depending on the rest of the frame members may not be necessary. In a case like this, where the frame members are light, the belly pan can give the stiffness needed to perform like a heavier drive train. |
Thanks to everyone for the info! I don't think my team really has the resources to make a bellypan, but it's always good to learn.
5188 used baltic birch plywood last season. It really doesn't get much easier than that. Just cut a square the size of your frame and rivet to the bottom. We got a 4'x8' sheet from the local Menards.
Though, my team has very strong aluminum welding capabilities, so we will probably stick with what has worked for us so far. Also, our robots have weighed in at about 100 pounds the past two years, so we should probably work more on increasing our scoring capability than trying to fix problems we've never had. |
#10
You could do a little, though it probably won't save you much weight at all.
#11
https://scontent-lga3-1.xx.fbcdn.net...b2&oe=5821B827 |
