Go to Post You all are brilliant people. - Andy Baker [more]
Unread 21-07-2016, 10:02
KJaget's Avatar
KJaget KJaget is offline
Zebravision Labs
FRC #0900
Rookie Year: 2015
KJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud of
Re: paper: ZebraVision 4.0 Neural Networks
Team 900 mentor here
Originally Posted by Turing'sEgo View Post
Based on my experience with deep learning, as well as many of my friend, it is really hit or miss when it comes to if a model will work or or not.
No argument. There's a good bit of science there, but probably just as much trial and error...
How many different architectures did you try before you decided on this?
We picked the overall architecture of cascaded of CNNs pretty early on. Initially we tried just a single CNN but couldn't find a balance between speed and accuracy that worked for us. We used LBP and Haar cascade classifiers last year so we at least understood the concept.
The architecture of each individual network continues to be tweaked the more we learn about them. The nets in the paper we borrowed from were too powerful - they're doing face detection, we're just looking for gray blobs so our nets needed to be simpler for a) performance and b) to prevent overfitting. So part of the effort was shrinking them down to a useful size and then tweaking learning rates and other parameters to get the most out of them.
What were the specs of the computer you trained on? (And how long did it take?)
To add to Marshall's info :
The nets we use aren't that complex. We did train on Marshall's monster Titan X machine, and that was nice and fast so we could iterate quickly. On the other extreme, some of the smaller nets could be trained overnight on a laptop running CPU code. That gave us some flexibility to play outside of the lab and then do a full run on the big system the next day.
Converting the individual input images to the database format used by caffe was a big bottleneck. As was not formatting our Linux drives with enough inodes. We had millions of 24x24 training images, and preprocessing them a few ways led to a file system with 10s of millions of small files. We ended up running out of inodes which meant that even though we had disk space free the file system couldn't create new files. We'll know better next year.
Did you find a discrepancy between boulder detection in your space as opposed to at competition?
Yes, or even in different locations in the lab. Gray boulders on off-white floors were our nemesis. Plus the boulders are reflective so the harsh red and blue lighting led to some really interesting color variation. I should post some of the stills - we really came to appreciate that gray isn't really just gray, no matter what your brain thinks it knows.
We initially grabbed a lot of data using the chroma-key process described in our data acquisition paper. That got us a good baseline to work with.
At that point, we captured videos from random places around our school and saw what didn't work. We used the imageclipper tool (see our github repo) to manually generate additional images of the boulders, and then used some tricks to multiply that data (adding noise, random rotations and brightness variations, etc). After a few iterations of this process we had a reasonable amount of boulder data to work with.
The other issue was false positives - detecting boulders that aren't actually there. Our initial set of negative (non-boulder) images was just random subsets of images we know didn't have boulders in them. Once we had the system up and running, we could run the detection code on full videos we know didn't have boulders in them. Luckily that's pretty much any random video not specifically related to the 2016FRC game. We captured images of anything detected in these videos and used them as additional negative images - basically retraining the net on things the last iteration got wrong.
Both helped accuracy a lot, with the down side being that it generated a lot of data.
Moving forward, I suggest taking a look at the winner of ilsvrc 2015.
MSRA sounds like some sort of antibiotic resistant flesh-eating bacteria
I'd love to have the resources to run a 150-layer deep network on the robot.
But yeah, there's lots of really cool new things out there and only so much time to keep up. I'd love to get some time to try out something like Yolo, single-shot multibox or Faster-RCNN and see if it can scale down to and embedded system. Running 1 net per input from should be more efficient than thousands if we can get the complexity down to something that'll fit on an embedded GPU.
Excellent work 900. I always look forward to these every year.
Cool! Glad to know people are reading. We have a lot of fun working with these projects.
Unread 22-07-2016, 15:32
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
Machine learning is really interesting to me, but unfortunately this whitepaper goes over my head. Is there a good starting point that you can recommend?
Unread 23-07-2016, 20:14
Turing'sEgo Turing'sEgo is offline
Turing'sEgo can only hope to improve
Andrew ng's course on coursera is an excellent start.
Unread 24-07-2016, 12:50
KJaget's Avatar
Zebravision Labs
FRC #0900
Rookie Year: 2015
This is also a really good resource : http://cs231n.github.io/. Pretty sure our students put it in the paper but I wanted to make sure it didn't get lost.
Unread 26-07-2016, 12:34
jreneew2's Avatar
jreneew2 jreneew2 is online now
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
I have a question for you guys. Did you ever actually use this in competition? I find that this wouldn't be that useful in actual competition unless you could track the ball, auto rotate and intake it with the press of a button. Were you able to implement that?
Still, very impressive as always! I look forward to seeing what you do every year!
- Drew
Unread 26-07-2016, 13:36
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
- Drew
Sadly not but we are very close to it and the purpose of our work has been to set ourselves up for the future, not necessarily for the current game. We're very focused on making the process repeatable and to learn from it and how to simplify/improve implementation.
This is really the next evolution of our work last year with tracking/retrieving the recycling bins.
Our hope is to program and complete a full "cycle" with our current robot once school is back in session and all of our students are back. We've even got a trick up our sleeve for tracking robot pose thanks to our friends over at Kauai Labs that should make this all a lot easier than it may at first seem.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 26-07-2016, 14:04
jreneew2's Avatar
AKA: Drew Williams
That would be really awesome if you completed that goal. I would love to see a follow up video if you ever get that working!
Thanks for the quick and informative response.
- Drew
