Re: pic: 25lb Drivetrain
Thanks to everyone for the info! I don't think my team really has the resources to make a bellypan, but it's always good to learn.
5188 used baltic birch plywood last season. It really doesn't get much easier than that. Just cut a square the size of your frame and rivet to the bottom. We got a 4'x8' sheet from the local Menards.
Though, my team has very strong aluminum welding capabilities, so we will probably stick with what has worked for us so far. Also, our robots have weighed in at about 100 pounds the past two years, so we should probably work more on increasing our scoring capability than trying to fix problems we've never had. |
You could do a little, though it probably won't save you much weight at all.
https://scontent-lga3-1.xx.fbcdn.net...b2&oe=5821B827 |
