Go to Post its ok to have opinions- but why attack everyone elses who differs. - stevek [more]
Unread 21-07-2016, 16:14
Knufire Knufire is offline
Re: pic: 25lb Drivetrain
Originally Posted by Cothron Theiss View Post
Thanks to everyone for the info! I don't think my team really has the resources to make a bellypan, but it's always good to learn.
5188 used baltic birch plywood last season. It really doesn't get much easier than that. Just cut a square the size of your frame and rivet to the bottom. We got a 4'x8' sheet from the local Menards.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 21-07-2016, 16:35
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Oh, you don't use a lightening pattern if you go with a plywood option? Nevermind, we could do that. (Now that I think about it, that should have been obvious.)
Though, my team has very strong aluminum welding capabilities, so we will probably stick with what has worked for us so far. Also, our robots have weighed in at about 100 pounds the past two years, so we should probably work more on increasing our scoring capability than trying to fix problems we've never had.
Unread 21-07-2016, 16:45
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
You could do a little, though it probably won't save you much weight at all.
Unread 21-07-2016, 18:03
Nope.
https://scontent-lga3-1.xx.fbcdn.net...b2&oe=5821B827
