Go to Post Yes, an expanded FIRST will look far different than it does today. - GaryVoshol [more]
Unread 22-07-2016, 11:53
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Re: pic: Outreach Frame/Prototyping Robot
Originally Posted by ASD20 View Post
If you want to make it for prototyping, you are going to want the mechanism mount point as close to the ground as possible for mechanisms that are low to the ground and height matters for, like intakes or a lot of shooters this year. You can easily make a robot taller, but not shorter.
Agreed. Id recommend bringing all the electronics to the back with a vertical electronics board. That way it takes up very little space and then get those 8020 rails as close to the ground as possible.
